Obecny czas: Wto, 14.05.2024, 0:45
[ 15 posty(ów) ] |
2016 Chevrolet Volt / Buick Velite
johny
Let's start with the numbers. The 2016 Chevy Volt will have an all-electric range of 50 miles from a new, 18.4-kWh lithium battery. It will get 41 miles per gallon (combined) once the battery runs dry and have 102 MPGe. Oh, and it has five seats, sort of. To compare, today's four-seat 2015 Volt has a 38-mile range from a 17.1-kWh battery in a powertrain that offers 37 mpg and 98 MPGe. So, across the board, there are notable improvements.
Now that that's out of the way, let's talk story. General Motors will unveil the new Volt at the Detroit Auto Show later today, but it's been talking about how this new version – the first major plug-in hybrid vehicle to get a serious redo in the modern era – was crafted with reams and reams of data from first-gen Volt customers. At a preview event for journalists last week, GM executive chief engineer Pam Fletcher told Autoblog that these owners "gave us the recipe" to make the second-gen model. At the top of the request list was more range (check), more "fun-to-drive" behavior (check?) and a smoother and quieter experience (we'll assume a check here, given that the new 1.5-liter four-cylinder – the first North American application of this new engine family – should offer more power with less noise than the previous 1.4-liter, four-cylinder powerplant). Other customer-driven changes in the new Volt include a different place to store the charging cable (in the side of the trunk instead of under the load floor) and a new brake system with improved blended regenerative braking feel as well as driver-selectable regen levels. The requested 50-mile range comes from a new, lighter battery that has increased capacity from fewer cells (192 vs. 288) and a simplified control architecture.
Along with the new battery, the electric drive unit is a two-motor deal that is up to 12 percent more efficient and 100 pounds lighter, while also being "tremendously smaller," notes Fletcher. It offers 294 pound-feet of torque and a maximum 149 horsepower of "motoring power" delivered to the wheels. GM says it has worked hard to reduced the amount of rare earth materials in these motors, and one of them doesn't use any at all. The new powertrain offers improved acceleration times, as well. The 2016 Volt can go from 0 to 60 miles per hour in 8.4 seconds, a seven-percent improvement, while the 0-30 mph time has been improved by 19 percent, down to 2.6 seconds.
The new Volt is more conventional looking, but certainly not completely ordinary. GM says the car's "eco attitude" is inspired by athletes and windswept sands, but we mostly see an emphasis on improving the first-gen Volt's wind tunnel aerodynamics while tacking towards the mainstream. The LED daytime running lamps on the outside front corners widen the car's apparent stance when it approaches, and in person, the car looks lighter, too.
On the inside, things have been toned down dramatically. Gone is the frustrating touch-sensitive panel that the designers plastered over the infotainment area in the first Volt. It has been replaced by a more traditional HVAC and infotainment system. We assume that you're noticing the trend here – the way GM is mellowing out the futuristic vibe of the first Volt even as it makes this second generation better. The idea is to be able to continue to attract early adopters while also targeting a broader audience.
Finally, for now, let's talk about the fifth seat, which requires the person sitting in the middle rear seat to straddle the battery tunnel. At the preview event, we were able to sit in the back seat alongside two other adult males, and let's just say that that everyone was more than happy to get out after barely three minutes cramped together. While the Volt is technically a five-seater now, the lack of a center headrest and the way that the rear bench is shaped to give extra comfort to the outboard passengers means that the middle person needs to sit on a cushiony hump with less headroom. Said another way, it's clear that this fifth seat is designed purely for kids or very short rides.
There will be more information on the Volt coming at the official press conference later today. When that information drops, we'll have it for you here, along with live pictures from the show floor. Stay tuned.
źródło autoblog
Broń Masowego Wyprzedzania
Pon, 12.01.2015, 18:23 |
c5tourer
Postów: 973
Samochód: FR, IT
Re: 2016 Chevy Volt
Wygląda jak jakiś pikaczu czy tam sticz...
Pon, 12.01.2015, 19:28 |
Iceman
Postów: 3300
Re: 2016 Chevy Volt
Oh, hello new Honda Civic. You look like a real crap
Cytuj: okol napisał(a): A juz IMO napewno lepsze niz obecne Bravo, ktore jest zupelnie nijakie.
Pon, 12.01.2015, 19:32 |
james_gastovski
Postów: 1354
Re: 2016 Chevy Volt
Okropieństwo. Totalnie pokraczna bryła, design zerżnięty z Hondy i ogólne poczucie taniości przez te srebrne wstawki z przodu. Pierwsza generacja była dużo lepsza, nie musiała się podobać każdemu ale przynajmniej projekt był spójny, oryginalny i futurystyczny. To jest pod względem designu taki Prius w wersji od GM.
_________________ Moja prospektów kolekcja niewielka
Pon, 12.01.2015, 20:20 |
johny
Re: 2016 Chevy Volt
Wygląda jak Hyundai na rynki rozwijające się, stylistycznie biedny, ale ma pro ekologiczny więc jakos tam się sprzeda.
Wto, 13.01.2015, 13:57 |
Alfisti4ever
Re: 2016 Chevy Volt
Trochę lepiej niż poprzednik poza tyłem wyglądającym tragicznie
Wto, 13.01.2015, 17:26 |
Bladyhel
Postów: 532
Re: 2016 Chevy Volt
Nienawidzę jednobryłowych aut.
Wto, 13.01.2015, 20:51 |
okol
Postów: 2693 Miejscowość: Człowiek z nikąd...
Re: 2016 Chevy Volt
OMG, kolejny zolw bez przodu i jeszcze ten tyl jak z jakiegos miejskiego sedanika z indii - dlaczego chevrolet idzie ta sama droga co paskudne japonczyki? PASKUDNE azjatyckie rysy.
_________________ STOP! ukradaczom tożsamośći! i ACTA tez stop.
Wto, 13.01.2015, 23:51 |
Re: 2016 Chevy Volt
Pią, 30.01.2015, 20:27 |
Re: 2016 Chevy Volt
Pon, 05.10.2015, 12:11 |
okol
Re: 2016 Chevy Volt
Te okienka, szczegolnie z tylu to moze calkiem zlikwidowac?... bo juz i tak sa wielkosci iluminatorow w czolgu...
Pon, 05.10.2015, 23:50 |
Re: 2016 Chevrolet Volt / Buick Velite
Wersja Volta produkowana w Chinach i dla Chińczyków będzie się nazywać Buick Velite. Rozmiary: 4579/1811/1494 mm, rozstaw osi: 2694 mm, masa: 1610 kg. Samochód napędza zestaw hybrydowy zawierający silnik benzynowy 1.5l o mocy 99 KM i zużyciu paliw poniżej 1l/100 km chinacarforums, carnewschina
Wto, 27.09.2016, 12:22 |
Alfisti4ever
Zastanawiało mnie zawsze czemu oni w Chinach tak tego Buicka lubią
Wto, 27.09.2016, 15:54 |
Toż to GMowski premium tamże. Między Chevroletami a Cadillakami. No i grubo wyżej niż Baojun, Wuling i Jiefang - z tego samego joint-venture Shanghai GM.
Wto, 27.09.2016, 19:32 |
Czw, 13.04.2017, 9:04 |
[ 15 posty(ów) ] |
