Obecny czas: Pon, 13.05.2024, 15:16
Otokar - pojazdy wojskowe
Post Otokar - pojazdy wojskowe
Otokar Cobra
Mobility
The Cobra's power/weight ratio is higher than 30 HP/ton. The powerful turbo diesel VB engine gives Cobra power to navigate the toughest terrain conditions. An electronically controlled automatic transmission, permanent four wheel drive and 2-speed lockable transfer box ensure high mobility whatever the terrain conditions are. An independent suspension and Central Tyre Inflation System make the Cobra the highest mobility armored vehicle in its class.
Survivability
The optimized body angles of the monocoque hull structure provide Cobra built-in survivability. This, together with a low silhouette and high mobility in all types of terrain, result in excellent level of survivability. Run-flat tyres, provided as standard feature, allow the vehicle to continue its mission, even with deflated tyres.
Transportability
The compactly designed Cobra is transportable by aircraft, helicopter, truck or railway, suitable for rapid deployment forces.
Cobra Open Turret Personnel Carrier
Suspension structure, rapid ingress and egress capability provided by the wide doors of Cobra vehicle ensure safe transfer and easy interference of the personnel. Vehicle's monocoque body and its wide wall angles are designed to provide higher ballistic and mine protection and due to its low profile, it is not an easy target to detect.
Cobra Closed Turret Personnel Carrier
Otokar designed closed turret, enhances Cobra's effectiveness in day and night conditions during missions such as border control, road and strategic area protection and fire support to the teams in combat area.
Cobra 40 mm AGL ve 12.7 mm MG Vehicle
The 360° rotating turret with twin guns has an ergonomic design and a low profile appropriate for various roles and missions. The turret provides possibility of surveillance and rapid firing against both ground and air targets from inside of the vehicle under protection.
Cobra Ambulance
It provides safe transport of patients and medical crew to risky areas. All necessary medical equipment for first aid is placed on the vehicle.
Cobra Reconnaissance / Surveillance Vehicle
This vehicle is developed for target acquisition and information feedback to higher command units under severe battlefield conditions. With its computer-controlled mission equipment, the vehicle can sustain undegraded operation under day/night and all weather conditions.
The electro-optic sensor system and ground surveillance radar can either function independently or in complementary modes. target information is transmitted via frequency hopping and targets are displayed through RF microwave link.
Cobra Command / Control Vehicle
Cobra Command / Control vehicle acts as a part of the command and control chain or as a command post and provides operational and regional intelligence in peacetime or engagement operations. The data collected via the vehicle's communicational subsystems are processed in a computer-aided environment.
Cobra EOD Vehicle
The vehicle is developed to act against explosive attacks in airports. A hydraulically controlled blade, manufactured of the same armor materials as the hull and located at the front of the vehicle, can be controlled from the driver's position.
Cobra Amphibious Vehicle
Double hydraulic thrusters with joystick control and position controller radiator aperture enables amphibious operation eliminating need for pre-work.
Cobra Giat 20 mm Cannon
Cobra fitted with GIAT's 20 mm 20M621 cannon is designed to meet ground to ground and ground to air missions including patrol, protection of sensitive areas and participation in defense roles.
Cobra Remote Controlled Weapon Station
Cobra APC fitted with remotely controlled weapon station has a flexibility to accept 7,62 GPMG or 12,7mm HMG or 40mm AGL to its weapon station which is coupled with FLIR and day camera. Totally controlled by the gunner within inside of the protected compartment, the vehicle has a crew of 3 and accommodates additional 6 man personnel at the rear. The vehicle forms an efficient platform for patrol under day and night conditions.Otokar APC
Otokar APC
Image Image Image
Mobility
Otokar APC uses proven drive train and excellent suspension. Permanent 4 wheel drive with lockable differential, high articulating helical coil springs ensure maximum cross country mobility with a power / weight ratio as high as 37 HP/ton, run flat type combat tyres, high acceleration and small turning circle figures.
Otokar APC with its design, mobility and protection suits for a number of military and security poles such as;
Armored Personnel Carrier
It is an armored 4X4 vehicle appropriate for various military and internal security missions. It carries military forces rapidly and under protection in risky areas with its high mobility, superior stability and "all terrain" capability.
Armored Ambulance
With this vehicle, it is possible to reach and transport the wounded personnel at the front line rapidly and under protection. It is equipped with first aid equipment for the transport of patients in a safe environment.
Armored Workshop Vehicle
This vehicle, required specially in critical areas, has various equipment and workbenches for maintenance and repair works. Furthermore, it provides the transfer of the maintenance staff in a safe environment.
Otokar Akrep
Mobility
Akrep is light in weight, fast moving and extremely maneuverable. Its high Power/Weight ratio and long travel suspension ensure mobility not only in urban conditions but also over all types of terrain in all weather conditions. With its compact dimensions and low weight, Akrep has capability of high mobility in even very narrow streets.
Reliability
Akrep's rugged design, using well proven off-road vehicle components available worldwide and its ease of maintenance ensure an enviable level of reliability.
Survivability
Akrep's low profile, ballistic hull design and special armor protection and renowned agility are all designed to maximize its ability to survive in high treat environments. Each armor plate is laboratory tested and certified. Each panel is stamped prior to production and fully traceable.
Logistics
All mechanical parts of Akrep are of proven , commercially off the shelf components which maintains easy logistic support. These parts are well proven for their reliability, availability and low maintenance requirements. All systems can rapidly be controlled and maintained.
http://www.otokar.com.tr
Wto, 11.03.2008, 16:37
Postów: 262
Samochód: Mitsubishi L200 2.5D
Post Re: Otokar - pojazdy wojskowe
fajne woziki :lol: bardzo fajnie wygladaja
Wto, 11.03.2008, 17:03
