Wheels/Tires/Suspension
Nismo LM-GT4 18 x 10.5 +15
Nismo flush centre caps
Advan Neova AD08 tyres, 285/30/R18
MIDORI development ARAGOSTA ERS custom modified suspension
(damping
force adjustable)
EIBACH springs
BCNR33 Front Lower Control Arms
MIDORI Development Pillow ball tension rods (castor rods – rose jointed)
NISMO reinforced Upper link/Upper Control Arm Bushes
MIDORI development Rear Pillow Ball Upper Links bush replacement (rose
joint bushes in upper control arms)
MIDORI Lower Arm Pillow ball bush replacement
MIDORI rear sub-frame collars
NISMO upgraded rear sub-frame bushes
Exterior
Exterior Parts
NISMO Side skirts
NISMO Rear side pods
MIDORI Development Carbon Fibre rear Wing Mounts (raised)
Front lip Spoiler painted body colour
Craft Square carbon fibre TCA-F side mirrors
Nismo R-Tune bonnet
Nismo Z-Tune front bumper
Nismo Z-Tune front guards
Qest LED tailights
Interior
Bride Cuga Japan edition front seats.
Nismo GT-500 Titanium shift knob
Nismo floor mats
Nissan TV option kit fitted
SONY navigation system
Engine
MIDORI Fine Tune engine maintenance –
Overhauled and balanced
Engine blocked cleaned ”WPC processing”
Fitted N1 pistons
Balanced connecting rods and pistons
Midori Intake and Exhaust Camshafts (256 degree duration and 9.15mm
lift both sides)
PBB Replacement Valve Guides
Valve face polishing (removes Nissan logo and smoothes valve surface)
Combustion chambers CC balanced and porting modification
0.8m Cylinder head re-surfaced/decked
HKS 1.2mm Metal Head Gasket fitted
Camshaft Oil seal replaced
N1 oil pump replaced
Valve stem oil seal replaced
MIDORI original development Oil Pan Baffle kit
MIDORI original development Oil Catch Tank kit
NISMO Inlet Piping kit
NISMO Air Flow Meter x2
OKADA PROJECT Plasma Booster Direct Ignition system
NISMO reinforced engine mount kit
SAMCO silicone heater hose kit
Turbo hardware
HKS GT2530 turbine kit x2
HKS upgraded adjustable wastegate actuators X 2
MIDORI original development Turbine Dump Pipes
TOMEI EXPREME exhaust manifold kit
Intake and Exhaust Parts
NISMO intake manifold/Plenum
HKS Inlet manifold metal gaskets
MIDORI original exhaust front pipes
MIDORI original High Flow metal catalytic converter
MIDORI original development Silent High Power Full Titanium Exhaust
System
HKS Power Air Flow “Reloaded” Version
SAMCO Silicone Suction Piping/Turbo intake piping
Cooling Hardware
ARC intercooler model M079 (hand fluted intake side, premium ARC core)
SAMCO Silicone upper intake piping (black)
HKS Oil Cooler kit Type S, with duct and 15 row core
CALSONIC Aluminum radiator
CALSONIC radiator cap
SAMCO Silicone radiator hose kit
Fuel System
ID1000, Fuel Injectors X 6
TRUST Fuel Injector Rail kit
SARD adjustable Fuel Pressure Regulator
NISMO 248 L/h High Volume Fuel Pump
Driveline Parts
ATS Carbon Fibre Twin Plate Clutch
Other Drivetrain Parts
MIDORI original development Clutch Slave Cylinder
NISMO upgraded gearbox mount
Electric Parts
MIDORI original custom tuned ECU
NISMO MFD expansion kit
HKS EVC 5 Boost Controller
NISMO 320km Full Scale Meter Kit
R34 Best JDM ever
źródło stancenation
